I'm having a little trouble tracing down my problem. All electrics on the bike work, it's a '74 CB450. Previous owner appears to have bypassed the kill switch. I'm not getting a spark at the plugs. I am getting power to the points, however. Bad coils?
The points getting power means nothing if they aren't opening and closing, or making good contact when they do....Try shorting across the open point with a small screwdriver and then "unshort' and see if the plug fires....
66 has you on the right track. Make sure the point wires are attached correctly as well and not grounding out befor it reaches the breaker.
Ok... try this.... Remove the spark plug "boots' from the heavy wires (they unscrew)....Slide a paper clip down the center of the wire and wind it around the top of the plug... (clip off excess... ) If it now fires, you have bad boots...If not bad coils or plugs........
well.. i shortened the wires by clipping about an inch off and then screwing the caps back on. Still nothing, even with known good plugs. I've also tried known good caps that I have from another honda. The only thing that I don't have that I can swap is a pair of 2 cylinder coils. Is is possible to use a single coil from a 4 cyl bike for testing?
Yes and no...(they are internally wound/connected differently).. You can wire one of them to one set of points and check that one side, but the dual lead coils require both HT leads have access to a ground (through the plug gaps), so you'll have to rig an extra plug on the extra wire, sitting on/grounded to the head loosely....DO NOT hook it to the plug in the other cylinder......
