Greetings all,
I have a 1978 cm185t (Honda Twinstar)
It used to run great 5 years ago when I got it. It would start with kick or electric start. Then it started to fail when idling so I would have to rev the engine to keep it running at stops. I stopped riding it last summer deciding I would replace the carb and clean the oil screen when I got around to it. This spring I did those things as well as replacing the contact breaker which looked damaged, and I tested the ac generator too. I also bought new plugs. Now it hasn't started for me even at a rolling start.
Looking at the spark plugs I see they don't have any spark when I electric start it. I used a gap tool to gap them properly. The manual said this could mean a broken ignition coil or condenser. I tested the condenser and it failed, so i just put a new condenser in. Testing the coil, primary wires showed continuity, but the secondary wires failed. So i ordered a used ignition coil and again the secondary wires failed for continuity. So i ordered a new universal 6v ignition coil and even these secondary wires failed.
My question is, what is going on with these secondary wires? Am I misunderstanding how to test their continuity?
And if anyone has advice on why I am not seeing spark, that would be appreciated. I have only been working on the bike for about two months, so my knowledge of bike repair is very small.
Thanks, Nate
Thanks, Nate
