My 76' CB360t is unresponsive despite a full battery charge and new fuses.
I'd had issues for a while due to an improper headlight (H4 55/65W) but just replaced it with a new H4 35/35W. In tracking down that power draw I'd replaced the rectifier/regulator with the Sparck "12V Single Phase Regulator/Rectifier" updated component, otherwise it's all stock parts. After installing the new headlight the bike started once and idled at a very high RPM, I killed the engine after like 15 seconds of it running and then could not start it again, though lights still on. I'd found that the battery quickly fell from 13.1V to 12.3V, which is usually enough to kickstart the engine but not working this time. Then on charging the battery back up to 13.1V, nothing turned on, including the neutral light. I read proper voltage at the main fuse with key on but nothing at the light fuses. I'd replaced the fuses despite looking fine and tried unplugging the headlight in case of some malfunction there with no affect. My guess is something is shorted from the time it ran, I checked for poor connections at the areas I had touched recently but no luck.
Where would I begin to check for malfunctions?
