trying to get my front blinkers working. one of the green wires to the headlight has been cut by the po and spliced into the orange with white stripe wire. from what I can see on the diagram it goes to the black connector for the turn signals. I ran an extra piece of wire into connector and speedo and tach lights came on. its a black wire on other side of the connector .one of the wires coming from the left blinker is black with a small piece of white jacket on it cant figure out where this hooks up. the right blinker has a two small pieces of jacket light blue and white found light blue with white stripe wire and hooked it up so pretty sure that's hooked up right. I got a solid orange female connector hooked to nothing its got power with a test light but other side of plug is not there. I have all other lights back blinkers work and front running lights come on just no blinker function. but when I switch left blinker on the speedo and tach lights turn off. also the po has this bike wired up where you have to take battery cable loose to kill power. probably didn't have a key so its hot wired somehow cant find where though. the ignition switch connector is intact except the black with white stripe wires have been cut and spliced together. the po said solenoid was bad so i bought a new one he had been crossing the solenoid out to start it. push the starter button and dash lights go out but no starter function. if anyone here has fixed similar problems help me out please
