ok someone square me away with this issue. How important is it to have a good working exhaust. My baffles are rotted out and are crazy loud. I'm assuming it has zero back pressure because of this. Secondly how or what does back pressure do to a running motor?
72 CB 350
on my cl350 it wouldn't turn up to the higher rpms with out some back pressure, had to make some baffles to fit emgo shorty mufflers
As Jayel indicated, usually some sort of baffling is required, or you'll have to invest a lot of time in re-jetting and tweaking, and it still may never run right.
When you diverge from design parameters that much, you're on your own and it usually has mixed results.
I'm running a CL350, with straight exhaust, without any adverse effects, I'm using a 117.5 main jet with the straight-pull SL350 carbs. FYI im at an altitude of around 4500 ft. I have superb power above 4000 rpm and moderate power up to 4000 rpm....I say go for it, the stock exhaust is clunky, heavy, and mostly rusted through after nearly 40 years, make it an artistic project...make it unique...make it your, not old man Honda's!
