Okay,
So I got my 200 running. top end was honed and reassembled with nearly new pistons and new rings. Motor fired and ran great all through the jetting and tuning process with no problems. finally got her out for the shakedown ride and things started fine. still needs a little carb tweaking but the motor ran great for about 10 miles then after accelerating from a light the motor stalled. there was a lot of smoke coming from the breather tube. exhaust not smoking at all. I was right down the street from a buddy's shop so I stopped there we started it again no issue. tweaked the carbs a bit and off I went. I went about another 5 miles and it was again running great, then all of a sudden it just quit. the bike didn't lock but the motor just stopped running at about 30 mph. No electrical issue apparent. when I tried to restart it the kicker felt like it was stuck in molasses, no weird noises nothing crunchy or metallic. just felt like a big bucket of goop with nuts and bolts in it. I pushed it back to the shop. (thank god its a 200.) when I got back about 10 minutes later and tried kicking it it was locked. I could shift through the gears but the top was stuck. I put it in gear and rolled it back forth a few times and it came free. I let it sit and then kicked it and it started like nothing was ever wrong. What gives? I had the bores and pistons measured and it all was supposed to be good, does this sound like bad pistons/rings or simple overheating or what? forgive my inexperience please. could use a hand here.
