I recently purchased a 74 CB360 that needs to have the tach cable replaced. My question is, how do you disconnect the cable from the engine? Mine is locked in tight.
Any advice would be appreciated.
Remove the retaining screw (Phillips head)....Pull cable out....
Tried that, but the cable seems to be jammed. I'll give it another shot tomorrow, put a little more muscle behind it.
Thanks!
I came into this same problem when I wanted to replace a leaky seal. I used a dremel to create room for a flat head to fit in the bolt. With a little bit of elbow grease (and some wd-40) I was able to turn the bolt. I also had to create a smaller wheel for the dremel to fit in that area.
