Hi all,
I've recently installed new back turn signals. They're working fine when I use switch on the handlebar, however they aren't blinking, just stay lit all the time.
What should I have looked for in turn lights specs before buying them?
Honda CM400T 1980.
Thanks!
Just replace the electro-mechanical flasher module with an electronic one that does not require a specific wattage loading........
Peetonn, I'm pretty new to Honda but on my old Yamaha the bulbs had to draw a certain wattage before the flasher would blink. The lower wattage turn signal bulbs were more common at parts stores and it was a common mistake to put those in instead of the higher wattage bulbs. If Honda is the same try higher wattage bulbs. Or swap for a non-mechanical flasher unit like 66Sprint says.
