Alright so I picked up a 350 today, with no fuel lines attached.
my petcock has one nipple, no return side on the opposite side of the tank.
I have 3 hoses coming from the top in the middle of the carbs, two of them go down the swing arm, the one in the center isn’t connected to anything.
I also have the 4 nipples on the bottom of the carb.
how do I route this bad boy?
Go https://www.hondatwins.com/forums/forum.php
Did you ever get an answer?
A TRUE CB/CL/SL 350 fuel tank will have (2) outlets on the Petcock if it has the correct Petcock installed.
The Carbs will (4) Brass Nipples
The (2) smaller ones on the bottom of the Float Bowl are the Over Flow Outlets they drain to the ground
The (2) Larger ones are the Fuel Inlets and go to the Petcock.
Your Tank should also have a Cross over tube on the bottom towards the rear(Seat End)
The Main Frame tube runs down a channel in the tank and the cross over allows it to even the fuel level side to side.
Without that it would only use half the tank.
If your Tank doesn't have them its most likely NOT a 350 Tank or they were welded over.
Reactions: Guitargeak99
