hello. I found this forum looking for simple information to help me correctly assemble my 1969 Honda CB350 (purchased disassembled).
I have 3 loose, unplugged wires coming out of the main wiring harness above the coils/condenser/ignition....gray, light green and purple. The purple wire is obviously not original because it has a soldered on multi-female connector with the cover missing.
I have 2 unplugged wires from the turn signal winker...black and gray. I have 2 wires unplugged from the horn...black and light green.
Which wires go where? The black wires and purple wire are "positive"?
Where is the proper frame bolt to ground my negative battery lead?
WE know the Purple wire ends in a multi-female connector (How many connections possible?), but can't tell you where or what connects to it until we know where it originates.....
Follow it back and find what color code Honda original wire it is connected to........
Turn relay plugs into the grey wire and black(hot) wire
Horn plugs into the mint and black(hot) wire
Neg battery ground bolt it the rear upper right engine bolt
Like sprint66 says, find the original color to the purple. If black then it's hot. If green then it's ground
