1 - 15 of 15 Posts
hey guys
about a year ago i bought a 1978 honda CB400 i got it running fairly well but i do not have the knowledge to get out the last few kinks
can anybody help???
ericpete said:
..... well but i do not have the knowledge to get out the last few kinks
can anybody help???
Probably, but you have to let us know what the problem is first.
Welcome.
The air-cut valve diaphragms on the carbs were a common problem.... But until we know the symptoms we are just guessing blindly........ :roll: Steve
for some reason the engine dose not get enough air it will only run when the lid on the air box is off
Did the air filter/cleaner element EVER get wet? If it did, the paper can compress and not pass enough air..... Replace the element.....
Also, are you SURE the choke is completely open?...The cables tend to stick.....
Third option...The carbs are flooding....Clean and adjust floats and check shut-off needles and seats
it is not the element and i cleaned out the carbs recently i think something in the airbox might be blocking the air flow
Wouldn't be the first time a rat's nest inside the element was the culprit......I've even found one full of dogfood squirreled away by some rodents.....Remove the element and see how it runs....(with the cover back on)... If it's appreciably better, replace the element with a new one!....(you can't always see the element is "bad" just by looking)
GB... CLOGGED jets would cause a lean condition.... It almost has to be a clogged filter, or partially choked.... OR flooding .....
My bad Steve. I figured he might have an air jet or something along those lines clogged, causing it to be overly rich.. I'm not terribly familiar with those carbs...
I edited my previous post, so as not to confuse him further..
I don't know your exact symptoms - but check the exhaust for free-flow, also. A partly restricted exhaust can produce similar flow-blockage symptoms, usually runs OK at low speed, but no power when you ask for it. Run it without air cleaners to eliminate intake restriction possibilities, see how it goes.
1 - 15 of 15 Posts
