I don't know that anyone really knows what MMO is! Hence the second "M" in the name: Mystery!Isn't marvel mystery oil half atf halve kerosene, basically the same thing? I'm open to anything better.
This CL was purchased in September as a sort of birthday present to me. It was a project that had been stalled for three years, according to the former owner.I've been reading alot here since getting a 72 cl175. The engine is locked up and I've put mystery oil in cylinders and in intake/exhaust ports.
A few questions;
- can't I just put a stronger bolt on the stator side to try and break it free? I've read to be careful not to sheer off bolt head. And also it would be breaking the engine free in the wrong direction.
- if I pull the engine now, how would I get the cylinders free from the corroded pistons and rings without prying on the fins or other parts? I don't know how to disassemble if these parts are rusted together.
-If I free the engine up won't it immediately score the cylinders? Should I put new rings and possibly pistons in as a minimum, assuming both are rusted?
-anyone have complete exhaust system for a 72 cl175?
Oil has been penitrating since Friday. So far she is rock solid seized.
Thank you all in advance!!
Looking forward to getting her running again.
The only thing you'll accomplish by doing that is removing the alternator rotor. If you want the best possible results - as in maybe you can actually run it after breaking it loose - why do you seem to be in a hurry?So broke a few bolts, double nutted with a big washer trying to rotate the engine with the 8.8 x 1.25 bolts I bought, and now thinking I buy this puller and thread it in and torque on this a bit. Any thoughts?
Problem is, in tightening it enough to actually try to rotate the crankshaft, it pushes on the end of the crankshaft to push the rotor off the taper... so well before you'd ever get the leverage you're looking for to even think about turning the crank, the rotor would pop off. The oversized bolt doesn't just facilitate pulling the rotor, it IS the "puller"I figured if I dont pull on it and just rotate on it, it would work better than just the retainer bolt.
