I bought a new fuel tap from Sirius Consolidated in Canada for my cb350 twin. It has one fuel line off of the carb into a brass "T", with a fuel line off to each carb. I'm concerned because the single line off of it means theoretically half of the fuel flow to the carbs as the old fuel tap which had two lines directly off of it, one to each carb. (Inside diameter of the lines are the same).
Has anyone had expereince with this new type of fuel tap, and am I needlessly worrying about the possiblilty of fuel starvation?
Thanks
it should be fine, it doesn't suck gas quick enough for it to starve the carburators. plus those fuel lines are plenty thick enough to start with, should give good gas flow regardless. hope this helps.
Thanks!
