I'm looking for a new or second hand upper yoke (or fork bridge) for my Honda CB350 K4 with little luck. But I've seen a lot of second hand yokes from earlier Honda CB models that look to be the exact same size but don't have any pinch bolts to hold the forks in place. Could I use one of these instead?? Thanks in advance
No, the early parts are very different in width and as you have noted no pinch bolts.
Make sure you use the spacer washers.
I think there is a company that has new castings made .... The CB/CL360 part will fit as will the CB350 4.
Ah right, thanks so much. I didn't know which other models could fit. Would this work?
Else, guess I'll have to pony up the cash for the CMC one
