Just noticed that the neutral light lights up when the gear lever is moved into first gear. It goes out when shifted into neutral. Is this a simple adjustment? Hopefully.
Maybe.... Under the sprocket cover on the end of the shift drum is a plastic "cam" held on by a machine screw.....
This cam has a key that orients its positioning on the drum built into it....
The screw could simply have come loose, or the key could have sheared,
OR, the brass strips the cam operates as an on switch could simply be bent out of position....
