Hey guys n gals, I’m nearing completion of my CL350 engine build. For some insight if you haven’t seen my build thread or other post, my right cylinder exhaust cam lobe had some wear on it when I tore the engine apart and I sent the cam and rockers off to Delta Cam for a resurface and hardening. I received them back and kept them in the box until now, just giving them the cursory, wow they look new look over.
I admit this was my 1st build and I didn’t inspect the rockers too thoroughly at the time I tore the engine down or when I received them back. Now that I am to the point of installing them I notice I have 3 312 rockers and 1 non marked rocker. The other thing to mention is one of the 312 rockers has a wider spine on the underside and that rocker lobe contact looks different then the other 2 and different then the one with no marking. See below.
My CL350 is a 70 model. I believe this is what is called the skinny cam. I’ve seen pictures of the fat cam and it definitely appears fatter.
Engine serial for reference
Cam when received back from Delta Cam
all 4 rockers, The one on the bottom has no marking. The 2nd from the top has lighter markings and a thicker underside.
The underside of the rockers. The 2 on the left are the clearly identified 312 rockers. The third one is the one with faded 312 markings and the last one is the non 312, no markings. The 1st 2 (312’s) closely match. Lobes are nearly identical as I can tell and Center rocking points appear the same. The third with faded 312 markings has a slightly different shaped lobe face and the center rocker portion appears thicker. The last non marked rocker has a much different lobe face and the center rocker is nearly identical to the thickness of the faded 312.
I’m nearly 95% positive this means I need to replace 2 rockers. I’m bummed and slightly surprised this wasn’t caught at Delta Cam. I’ll be calling them Monday to inquire but I also know that it was my responsibility to look and inspect the rockers before, document better, and inspect after I received them.
Any insight would be great and if we agree that I need 2 312 rockers, anyone have some?
