Someone with a 72 CL450 K5 Scrambler with the stock factory exhaust system:
1. Is the exhaust tip baffled inside or just a straight pipe?
2. How long are the tips from the weld to the end of the pipe and are both the same length?
3. Are the ends of the exhaust pipes staggered or are both pipes even, ie the top one stops at the turn signal and the other is farther back? I've seen them both ways on the net and only one of them can be correct.
Mine have been sawed off and I want to try to find suitable replacements.
Thanks..Jerry
Both tips have an inner tube (not sure I'd call it a "baffle", but it is double walled.....)
Both tips are the ~same length from the weld to the end of that tip.....
The lower tip projects further rearward than the upper due to the muffler projecting further rearwards...(when viewed from the side)
Look here: http://www.motorera.com/honda/h0450/scr ... ramble.htm
However, since they will need to be rechromed after welding, it may be cheaper to just get another set on eBay or the like....
Thanks for the info.
I'd buy a set if I could find one but all that I've seen on ebay are pretty rusty.
Mine are almost perfect except the tailpipes.
