1 - 10 of 10 Posts
My name is Nick and I just finished takeing apart and putting back together my 1981 cm400a and she turns on sounds good but no mater the idle or how warm once I switch to first gear she shuts off does anyone have any ideas as to what's going on?
So either the clutch is assembled incorrectly, or the cable pull needs adjustment. There is a sticky on the cable adjustment process.
Did you alter either of these?
Edit: sorry, I just saw it's the a model. Disregard above. Maybe it's a kill switch. Is your side stand down when you're putting it in gear?
Yep. I think the a model has a side stand switch that cuts the ignition when put in gear and side stand is down
Welcome to the forum. Great to see another 400 series here.
1 - 10 of 10 Posts
