kind of a long shot but im trying to make forward progress on my 71 cb450 resto but i need a set of cases that would be deemed close enough to be original so im looking for a set of very late cases around 300 after my frame number cb450 4125652 message me if you have a set
thanks Dalton
Trying to understand your problem......Is your existing top 1/2 case not close enough numerically to suit you?
5 speed bottom 1/2 cases are interchangeable, and several THOUSAND numbers different was not that uncommon on factory original bikes....
Reactions: mike07
correct my top case is from a 72 currently so technically i do only need a top case and the gap seems to be a very debatable topic and being a later 71 the gap from frame to case is probably going to be larger. ive just seen so many conflicting opinions on that so if i stayed closer to my frame number i figured the better
