WTB: Brake Pedal for a 1974 CL360
I just picked up this bike. The brake pedal is bent up at an awkward angle. Looks like the bike had been dropped.
It had sat in storage for several years. Fortunately, gas had been drained and new oil was in the crankcase.
I charged up the battery. Cleaned the inside of the gas tank with muriatic acid. There was very minimal rust.
With a charged battery, clean fresh gas, and it started right up!
Turn signals, headlight, starter, horn....all work!!
Just need a new brake pedal.
The CL360 joins a 1970 CB450 and a Darkside bagger.
Thank you fellas
I have one I can offer. It appears to be straight but it does have a place where another part rubbed and wore a notch through the metal. I can weld this to repair it. I believe once I repair it the arm would be as strong as a new one. I can send a pic of the repair if you are interested but it may be a few days before I can have a chance to do the repair. Let me know if you are interested
19B2CE23-143A-4D24-A49C-2F43082875E0.jpg 581E7A93-553E-41A7-AE86-009DD217DFF3.jpg
Im not sure if you are still on the hunt for this but I went ahead and repaired the cut in it. Yours if you still need it.
