Can someone take a pic of their center stand from a 1973 cl450? I think mine is all goofed up (not the right one) along with the brake pedal. Thanks. If it is a pic of it off the bike that would be even better.
A single hollow shaft (#13) runs from the rider's right through the brake pedal, then the stand and frame mounts.
A simple washer and clip on the left side of the bike.
All 5-speed 450's are this way.
#12 is a little rubber thingie that keeps the stand from clanging against the frame when up.
The rubber thing is still available, the shaft may be also.
Ok, well appears that perhaps the pedal and shaft are not original. They were just jammed in there and were near impossible to remove.
