Nasty noise I think coming from the starter motor on my '79 CM185. Have a listen:
What is happening? Is this something to worry about? Wondering if the starter can be serviced, level of difficulty, or if I should look at replacing it.
Carbon dust build up on the brushes and inside. Take it apart and clean it out. I tested my starter on bench and it made that same noise. Got a decent rebuild kit and it went away.
That is not that bad. Mostly crud and old dry grease. I wouldn't worry about it.
Level of difficulty depends on the tools you have. Cordless impact comes in very handy. I now split the electric motor and leave the drive splines on the engine but if you have never seen the insides it may not be the best procedure to follow.
Sounds like the over-running starter clutch,behind the alternator, needs some attention.
I sounds like it is the starter clutch hub and not the starter motor. I just fixed my starter clutch hub on my 1968 CB450. Common-motor.com sells a kit (not sure if it is for your model). You will also see videos on how to fix it.
I also suggest servicing the starter clutch. On my bike I did that job (a CL175). Its easy to do. If I recall I had to remove the engine side cover and the fly wheel. There were three tiny rollers with springs inside that I replaced. The springs get old and lose some of their push and cause the starter clutch to not grip correctly. I don’t believe it’s a mechanically dangerous condition, just a nuisance. If the springs get weak enough over a long, long time your clutch may not get any grip and may not start the bike but I don’t think you are anywhere near that point. Good luck.
Reactions: Mike1000
NEED SELF STARTER SERVICE, ALSO CHECK MAGNET INNER FRAME INCLUDING STARTER CHAIN, WHICH IS ASSOCIATED WITH SELF
