I'm not especially proud of this one... :( In the process of unmounting the exhaust cam of my 450, during a manipulation of the head, this small washer fell from the exhaust cam bay. The tach gearbox was open so my guess is that this washer is the #90451-292-000, it fits just next the gear of the tachometer gear (#12431-292-000). So far this is the only place i found where it should be placed.
Not easy for me to be sure, i don't have any place to compare. Any other ideas?
Thank you for your input.
Yeah, that looks like it.
Many times oil will cause them to stick to the cam, then it falls off at some time after the cam is removed.
To put it back together you put it on the end of the cam/tach drive shaft first, then put the tach gearbox on.
