1971 cb450. In the process of rebuilding the ignition with new points and condenser. However i have a small electrical box device about one inch by 1/2 inch mounted on rubber grommets on the frame infront of the engine. It is not the coils or condenser as i can see them under the tank. Thisis mounted lower on the front frame infront of the engien near the horn. I have searched all over for what this part my be. Sorry i can not up load pics at this time. If anyone has any ideas please fill free to help me out.
turn the ignition on ... then turn blinker (indicator)on ...listen . I think it is blinker (indicator)switch you can also touch it and feel it pulsating
Discussion Starter #4
Here is a pic online i found that a believe is it or atleast i know its in this location. Sorry im at work and cant take pics of my bike. 6E7AF17D-6E74-47FA-B780-90C7F0C27A93.jpg
If the wires attached are black and grey it's a turn signal relay.
Discussion Starter #6
After searching flasher relay i found it. Thats it! I thought the turn signal relay was under the seat. Thanks guys!
