1 - 2 of 2 Posts
When ever I go to turn off my motorcycle it will not cut off when I take out the key? The lights will turn off but the engine will still run. I have to stall it out to turn it off.
Check the Black w/White bullet connector at the CDI unit. Left side of frame under the gas tank. It should be connected since that the ground circuit to turn it off. I'm guessing the Run/Kill switch doesn't work either.
1 - 2 of 2 Posts
