So I probably should have started this thread a little sooner as I have already begun tearing the bike down and working on the engine. I am not so good at documenting while working but I do have a couple pictures of what I have done so far. Right now I am in the middle of re-building the engine with new gaskets, valve springs, new exhaust valve (old one was bent), new exhaust valve guide, new engine top bolt to replace old one with broken oil seal, new clutch springs, and that's it I think. I have also sourced a new seat and hoop for the rear subframe. The hoop was pretty dope with the LED wrap around light already integrated into the hoop. I am now trying to decide how I want to attach the new hoop. My original plan was to do away with the stamped steel coming off of the subframe bend that catches the suspension and then weld on a new tube frame member to replace it. However, my buddy came over to take a look and said to just go ahead and do away with the hoop all together. I'm a little nervous taking that much out of the frame but I think it is do-able. QUESTION: Does the rear subframe bolt onto the front frame near the footpegs, or is it welded on? It looks to me that if I cut just above where the footpegs mount the frame can pivot at this point. Also, just looking for some advice or recommendations on what to do with the subframe. I have attached a pic of what I am thinking but am definitely open to suggestions. Thanks in advance!
