1974 Honda CB450 DOHC
ALRIGHT BACK TO BASICS...There are only so many things an engine needs to run, spark, compression, fuel, and timing.
Both carburetors have been rebuilt correctly and the correct amount of gas is flowing into the cylinders.
Both cylinders have about 150+ compression.
Both spark plugs are firing.
The cam and crank have been timed together correctly after rebuilding my cylinder head, timing for the ignition is timed correctly to the compression stroke for both cylinders.
The bike wont even fire up while I'm spraying starting fluid direct through the carbs (choked or not).
Is there something obvious I am missing?? WHY wont this bike start!?
thankyou all who respond i need as much insight as possible.
