No to the hydro lock. These carbs have overflow tubes. Hydro lock usually occurs with bikes that have no overflow tubes and usually vacuum operated fuel valves that fail in the open position. The cylinder must be almost full or partially full of fuel on the compression stroke when starting is attempted for hydro lock to occur. Nasty damage happens after that.My points are OEM.
ok Ill start referring to manual and just ask more questions! Im glad I found this sight becuase I wouldnt know enough to question common motor.
With my carbs being set a 23mm, or the floats too high in general, can it cause hydro lock?
You may want to do a search for other vintage honda sites......some have very good resource libraries ...
