Okay gentlemen I've come to you in my time of need for some advice.
Bear with me, I am relatively inexperienced, especially in this company.
Some potentially relevant information:
1971 CB450 K4 DOHC Twin
Stock Exhaust
Stock Airbox w/ Paper element cut out and replaced with UNI foam as per reco on here.
Stock battery box and subsequently stock size battery.
From what I can tell, original regulator and rectifier.
Coils have been replaced at some point, but do not know how recently.
Has a PAMCO electronic ignition system sourced from 4into1
Wiring harness as a whole leaves much to be desired but all lights/indicators/switches function, with the exception of the starter motor (more on that in a second).
Stock carbs with stock jetting.
So, as the bike currently sits, it is very near completion (or so I might optimistically think). The battery has primarily been stored for the past 7 months, as the rest of the bike was looked after; occasionally on a 2 amp charger. As I thought all else was ready, I charged the battery to full (according to the charger), and placed in the bike. I just rebuilt the starter clutch and the electric start system was working fine at that time. Now, the button does nothing. No electric motor noise, certainly no engine turning noise, etc. Thoughts?
Anyhow, the bike kicks over (and with only my '74 CB360 daily driver as reference, the kick seems less resistive, indicative of low compression; can this be caused by poor valve clearances or is it solely a cylinder and piston issue?). The bike starts on second or third kick (without choke) and runs on both cylinders, holding a decent idle. To me, again with only my 360 for reference, there was valve chatter (hence my earlier suspicion), but I don't have a proper running 450 to truly know the difference. After 30 or so seconds, the bike will slowly die, regardless of inputs. It will start again, but only run for a few moments.
My initial thoughts are perhaps loose valves and a **** battery (as after this cycle it was about 2/3 depleted (again according to the charger).
Could it be the charging system not sufficiently charging the battery to continue to run? Could it be failing coils?
Where should I start?
Thank you gentlemen, sorry for the long read. Hope my laimen nature won't impede the story. I will happily clarify anything else if it aids in advice and troubleshooting, as well as provide photos if necessary.
Stock Exhaust
