Re: Muffler Hangers - Photos
Chris -
The stock 450 muffler looks like this, with two welded-in studs to attach to the two bottom holes on your triangular piece. The top hole on the mount piece goes to the buddy peg bolt.
The triangular pieces are Left and Right, by the way.
I don't know what sort of aftermarket mufflers you have, but most of them are the Emgo type, in a lot of variants. Common to them all is the sliding adjuster and strap.
Many times, as with CB200, it's possible to use the stock mounting plate and ignore the chromed strap. I needed to do this because of the buddy peg anchor tab that fits in the slot you see on the top left of the plate.
Not happy with it, I'll use the strap next time I put it back together.
The 450 was relatively simple, just used the strap. Though there are many reports of folks using the stock mount plate on 450's too, similar to the CB200 photo. Looks like it might fit, but I didn't try it.
Just put the muffler onto the already tightened down exhaust pipe.
Work with both adjustments at the strap and get the muffler straight and everything lined up right.
Then tighten the strap on both ends, and finally tighten the clamp at the joint.
The joint will probably leak - I used this stuff (just the cloth) to fix it - from the auto parts store.
