1 - 2 of 2 Posts
Hey Fellas -
Recently rebuilt the carbs on my CL350 using this forum, a Clymers manual and several YouTube videos.
The step I'm having trouble with is remounting them back on the bike - every source I've used seems to skip this step and take for granted that I have the mechanical skills to figure it out - which I clearly don't.
My main issue is with reattaching the throttle cable and how (where? if?) the bracket-arm coming off the carb attaches to the cable.
Does anyone know of a video or tutorial that walks through this process? I can post pictures tonight if more detail is needed - I know I'm not using very technical terms here.
Thank you!
The Adjuster Barrel of the Cable threads into the bracket.
There is a SLOT the Cable will slip thru so you can then threads the adjuster into place.
1 - 2 of 2 Posts
