So, I am pretty darn sure I installed everything correctly according to the factory manual, however, I have to unscrew both barrel adjusters and have the adjuster on the case all the way in for my clutch to engage. Ball bearing is in place, the rod does not look like it has worn much.
-New clutch plates
-Aftermarket clutch lever (the length of the cable connection to the barrel looks the same as the stock clutch lever)
Any ideas? Thanks
-New clutch plates
Any ideas? Thanks
