Hello,
I'm pretty new to the forum (and motorcycles, for that matter), and this site has been extremely helpful to me so far, so thanks! I recently got a '72 CB350K4 that runs but needs several smaller things. Overall it seems to be in good shape.
I ran into a problem early on, though. I had ridden motorcycles some, but never kickstarted one. Now I cringe thinking about this, but I tried to kickstart the bike in the wrong way (clockwise). I later figured it out, but after a few proper kicks, the shaft wouldn't return up. I can still start the bike, but have to return the kicker by hand.
Yesterday I went to inspect the damage, thinking maybe I knocked the spring out of whack. I took off right crankcase cover and found that the spring was fine, but the part of the crankcase that it hooks onto had broken off. Also, a flatter piece of the case was broken off too, just below the clutch basket (it's in the blue box in the shop manual screen shot).
I think probably I'll have to replace the lower crankcase eventually, but don't have the space to do that for a while. Does anyone have any thoughts on if the bike's okay to ride like this? Or do you think these pieces could be welded back on? I'm okay with having a non-returning kickstarter, but I'm worried about the larger flat piece. Anyone know what it does, maybe it's involved in the lubrication system? Any help/insight is greatly appreciated, and thank you!
Tom
since you've gotten the pieces out you are ok. just remove the kickstarter so it doesn't flop around and ride it.
Take the kicker return spring out before buttoning it back up.... It appears as it will rub on the clutch primary gear, and COULD interfere with shifting.....
Thanks for the input with this. I took off the return spring and put everything back together, but now I have a new problem: when I start it up (using the kickstarter) it rattles or ratchets constantly. It was doing this before I took it apart and removed the spring, but the ratcheting would stop when I returned the kicker to the 12 o'clock position by hand, and then moved it slightly counter-clockwise. Now the ratcheting occurs no matter what position the kicker is in.
Any idea why this ratcheting problem would be worse now that the spring is removed? I've looked at a few other threads about ratcheting kickstarters, but couldn't really figure this out. Also, even though the spring wouldn't return the kicker arm before I took it out, it kept the arm from flopping around--I'm wondering if this has anything to do with this problem.
