found this spacer -washer on bike stand after working on it.i had both side covers and oil filter off.plus front brake lever and caliper off.does any one know where it came off of.i have looked at parts diagrams but cant seem to find it.i dont want to try and start it if this is missing some where. IMG_0101.jpg IMG_0101.jpg
kwr, did you find out what this spacer/washer is from? I think I have the same issue!
Is the spacer approximately 16 mm wide (Outer Diameter), 10mm wide (inner diameter), and 3.5mm thick?
I found it on my engine "workstation", so I think it came out of the left or right engine case.
It looks like a crush washer off a brake line banjo bolt.
TOOLS
Hmmm...mine are all MUCH much thinner and "shiny" aluminum.
OOOO!
Nice job! I will check myself when I get back home from work. It doesn't seem to be ID'ed in the Shop Manual. Is it between the oil filter tube and the o-ring in the following diagram?
