I recently ordered an extra piston for my bike after accidentally destroying one of my pair. I ordered using the same model number, and while close, this piston I received isn't exactly identical. While both pistons are the same height, and diameter, the new piston is has a slightly taller part where it is a complete cylinder, before the bulge on top. There is only less than a mm difference. My question is, does it matter? Or am I fine to put it in the bike as is?
What bike?
Any pics of the pistons side by side?
It's typically a good idea to buy pistons as a pair and not singly like that.
I wonder how close their weights are? While its of course your decision which parts you put into your engine, a balanced pair of pistons with the same weight and compression ratio may or may not need similar appearance. But I'm no expert and this is purely conjecture.
The height difference should be measured from the wrist pin and not the skirt. Unless there is a big difference in weight it should be fine to use the different pistons. I have seen engines with different pistons, even an overbore on one cylinder run for years without any problems.
TOOLS
