I am the proud new owner of a 1972 Honda CB350 that was running but now won't start up. I am trying to track down the issue and am working on an assumption that I was hoping someone could verify for me.
My question is this: When the ignition switch is in the "run" position, if the electrical system is operating correctly, I should be able to turn on the lights, turn signals, and horn. Is this correct? Even if the bike isn't running.
I just want to make sure I am tracking the right system when I am looking for the problem.
Also, if anyone has any advice on things to check: I've checked the battery. Have a connection along the red wire into the ignition. Read resistance between the red solder point on the key switch and both spark plug boots when the key is in the run position. The tail light works when the key is in "parking" position but otherwise I get no other sign of electrical life.
