Last month I made a nylon replacement for the rubber cam chain roller. Today while waiting on parts to arrive I decided to tackle another missing part I need. Also originally rubber. The intake manifolds.
My new carbs came with rubber connectors but without the flange for attachment to the cylinder. This is a pretty simple part to make. It's what I made it from that may raise some eyebrows.
First up was creating a pattern of the intake port. A tracing with paper was transferred onto stiffer cardboard for the working pattern. The base, the part bolting to the intake port, was made from a 1/2" pipe flange. The flange was sprayed with dykem and the pattern transferred.
Bear with me kids. This isn't going to look so dumb in the end... I think.
The extra bits were cut away with a angle grinder and then the flange milled to final contour.
Next the inner lip was beveled in the lathe and the center of the flange cut away.
Since the bevel is on the inside, it looks pretty rough in this photo.
Appearently I didn't take photos of that process but next up was drilling the base plates for the 6mm mounting holes.
Then I cut two 3/4 inch lengths of one-inch (I.D) iron pipe for the spigots.
I'm not much of a welder but I'm satisfied with the attachment of the spigot to the base.
The last machine operation was to chuck the spigot in the lathe and take a finish cut off the back of the plate to assure the spigots are square to the mounting surface... not that it is super critical since the carbs will be attached by a rubber sleeve. :-?
They will of course require separate gaskets unlike the original rubber units, but that's a simple fix to. I ran out of time for today, but they need some serious cleaning up. The interiors will be polished as smooth as practical.
