1 - 2 of 2 Posts
Just had the m.unit blue for my 72 cb450 installed. I was warned to avoid use of the keyless go feature as it bypasses the trigger wire for the regulator / rectifier (which is hooked to switched power) ... meaning the charging system won’t work when the bike is switched on w keyless go. This seems like a huge oversight on the part of m.gadget ... is this a commonly known issue in cb installs? Or am I mis-informed?
Seems to Me you could just wire the trigger wire to the black wire ,feeding the coils, it would switched on and off with the coils.
1 - 2 of 2 Posts
