Hi guys,
I have low compression on one side. On inspection I found the following ;
- Bores look good as new with no wear lip at the top
- Pistons are not scored and measure standard size
- Rings on both cylinders are way out of spec
- Valves look good, not burnt out but I suspect they could do with cleaning and lapping in
My question is, would you replace the pistons even though mine look fine and undamaged or would you just replace the piston rings?
Also, would you replace the timing chain (says DID on it?) or would you just fit a new soft link?
I was going to sell the bike as I have a SV650 which I ride regularly but have since decided to rebuild the 500T engine, tidy up some cosmetics and keep it.
Any advice on where to get piston rings from? I have found some aftermarket rings from Japan for £25 on ebay... is it risky?
Many thanks
Dan
Many thanks
Dan
