Last summer when I was running my bike, I noticed there was a lot of smoke from the crankcase breather after the bike is warmed up. The breather hose (luckily or not) wasn't long enough and after a 10-15 min run on the highway, I noticed a lot of oil on my swingarm and the sides of my tire. After rerouting the hose, I determined that the oil was coming from the breather and being flung off the tire. For ****s and giggles, I decided to put a catch can and see what's coming out of the breather. Surprisingly after a day of riding, the catch can had a tablespoon or two of water and not much oil. This was in the summer where I rode once or twice a week for a good hour or two. Oil has been changed at least 3 times within that summer and 3-4 tank of good fuel been through the tank along with stabilizer.
The oil is definitely a problem that will need to be addressed down the line, but I am curious if that much water is normal. I assumed all of it will just go out the exhaust.
Two things you can do:
1. Compression test/ leakdown test.
2. Monitor oil consumption.
Increased water vapor from the breather can be caused by infrequent riding and short trips but it doesn't sound like that applies here.
Water condenses inside the engine after shut down. More so if you live in a humid climate. Just the nature of the water content in the air. As you have found it flashes back to vapor and boils off once the engine is hot enough.
I wouldn't be too concerned about it as long as you are buying good fuel that doesn't have water in it.
Sent from my SAMSUNG-SM-G891A using Tapatalk
Water is a byproduct of combustion. Normally it comes out of the tailpipe. Frogman is correct about the quality of fuel. I try to by Chevron or Shell and stay away from commodity gas like Safeway, ARCO, Costco etc. Another thing, don't forget the cardinal rule: "Check the oil level before every ride."
Compression is 170/185. Engine probably has less than 2k miles on it since its been rebuilt by previous owner. I don't trust the numbers from the cheapo leakdown gauge I have but can definitely hear leaking past the rings. It was registering in the "OK" range on the gauge which was like 0-20% or something.
Not too worried, mainly just curious. Initially I thought I was burning up a lot of oil, but I rarely have to top off the oil. Once the bike is warmed up, there will be lots of "smoke" puffing out the breather (not a constant stream). I thought it was all oil because of my oily swingarm but surprised to see it was mainly water (or something that doesn't condense i guess).
