Just returned from a ride and saw the other thread on the locked front disc. I assume my 350 has the same holes. Is there a good kit for the master cylinder and the caliper? Is there a good vendor for these parts?
Thanks,
Larry
Larry, Unless you are doing a "correct" restoration, I'd recommend a replacement master... About $50 which is close to what the kit would cost, and it's NEW....(pics in Bills project 450 link)
You'll have to pump the piston out of the caliper to inspect it...If it's good, a new seal (big o-ring) is just a few dollars.....If piston is bad, about $60 for a stainless replacement through a member here....
