I would like to change my dodgy key switch on my 1981 CM400T. I could also use the opportunity to replace the scruffy tank cap and the helmet lock.
Is there a suitable lock set available for other machines which would suit?
I can get all the bits separately for the CM400T but would like to have the same key.
I am assuming by "dodgy" the switch is intermittent, it might be a lot cheaper and less of a hassle to disassemble it and clean it. Guts for the tank cap and helmet lock should be able to swap to new assemblies.
Don't forget the steering lock. Ignition and steering should be able to be recoded by a locksmith to match the gas cap. don't know about the helmet lock
