I’m needing someone to chime in here who's been down this path before. I repaired the wiring harness that was heavily “cooked” at the magneto/battery area and have connected the wires in the headlight bucket. I get the neutral light but no headlight, signals or tail light.
I have a female solid brown that has nothing to connect to it and the schematic shows a solid brown from tail light to the switch. Hmmm. don’t know what to do about that.
However, if I take a test lead and touch it to the bottom of the headlight bracket (where the green wires connect to the ring and adjuster frame) and touch it the lower triple clamp bolt, I’ll get headlight and tail light.
The front signals are OEM’s with two wires instead of one. I have a black from each going to the respective lt blue for right and orange for left with the extra wire going not attached to anything. I have the same scenario there; no turn signals, but when I touch the unattached wire to the triple clamp bolt, they’ll light up solid – no wink.
With the CL175 the headlight bucket ears are completely isolated from any ground contact with the frame bits due to the rubber grommets within the ears and the rubber bushings at the top triple clamp.
How do I get the bits to light without cobbling up a makeshift ground?
Thanks, Tom
Thanks, Tom
