Hi,
I have a 1971 CB350
I got one of those common keyster rebuild kits to rebuild my carbs, they are pretty weird... like half the stuff isn't what I have in my bike, some of the jets are the same, most of the o ring stuff doesn't fit. We ended up self-fashioning o rings and such to make it all work out, gasket didn't fit, etc.
Anybody know how to find the exact stuff? Or is it impossible?
Just wondering cause they are a bit leaky now...
Also L side carb keeps draining out the drain hole in the bowl. Does this mean the float needs to be adjusted or the needle valve adjusted or something?
Thanks.
You can still get a complete set of all the O-rings and gaskets for the carb from the original manufacturer for around $15.
Honda part number 16010-344-305, I believe, for our bikes.
