1 - 2 of 2 Posts
Any body else have the left cylinder stop working after installing the Pamco ignition and driving for about 30 kms . Funny thing is that when i slowly pull the plug wire cap off the plug the cylinder fires up and runs if you leave cap loose at the end of the plug. If you push the cap back on the cylinder stops firing again. ????
Honestly, it sounds like a partly fouled plug... my Dad used an old trick on his Harleys back in the day (flatheads) when the rear cylinder would foul a plug - he'd take a matchbook cover and roll up the cardboard from it, slip it inside the plug cap and put it on the plug, holding the connector in the cap slightly away from the plug top... worked every time. Try a new plug in it, see what happens
1 - 2 of 2 Posts
