1981 CM400T
So,
I was going to swap the oem flasher as i changed the original turn lights with led ones,,,hyperflashing,,,,
now,i was sure it was a 2pin flasher so i ordered one,today it turns out it's a 3 pin,,,so,now i have 1 oem 3 pin flasher,one aftermarket 2 pin for leds and the 3 wires (green,black and grey) hanging loose,,,,
Is there any way to wire the 3 wires to a 2 pin relay,or should i get a 3 pin,,,also,now i messed with the wires and dont know which one goes where :#
Any help would be appreciated
Thanks
Toni
don't use the green
1981 CM400T
Simple as that? Will try that,thanks
Different bike but the wiring is the same. This is my 500T with a 2 wire LED flasher. I did have to reverse the wires as you can see. Grey to black and black to grey
1981 CM400T
Ok will try that tomorrow,hope wont burn something :)
On mine I connected it color to color, nothing burned up it just didn't work. I hope yours is the same
Moved to SOHC Electrical
Most of these models are using a 2 wire flasher and the Green is usually found hiding behind the electrical panel unused
1981 CM400T
The new 2 pin flasher i had was faulty...lost an hour on the bike trying until i went benchtesting it...and there you go,the sucker doesnt work,,,dead....should have bench tested first :/ ordered and put another same one,this one works great!the green wire hangs loose as you said
Thanks guys
