Had a cylinder running a bit lean, not excessively but more than I liked. Did all the usual things, clean and sett up the carbies, checked the timing and ignition system all ok. Then found a leak on the exhaust manifold which when fixed solved the lean cylinder problem.
I am a bit doubtful, is it really possible that a leaky manifold would cause a cylinder to run lean or is it just coincidence that the problem went away after I fixed the leaky manifold?
