1 - 1 of 1 Posts
Has anyone ever used Rustoleums Krud Kutter Rustex Rust Converter? I gave it a try cause my 450 project frame had solid rust and I wanted to make sure that the rust will not come back. So after cleaning and sanding the frame I've painted it and let it sit overnight as advised. Next day the frame had a nasty very sticky surface as if I've treated the whole thing with sugar water? Not being able to imagine to prime on this surface I've painfully removed everything which was in fact worst than removing the original paint. So after two days of work I'm back where I've started.
To me this product don't make any sense cause light rust just turns black and sticky so you want to remove it anyway and heavy rust is still there underneath, even if you paint thick. Maybe it is my fault but what I could say about this product would violate PG rules...
1 - 1 of 1 Posts
