The Silvers K1 exhaust pipes do not have the front mounting brackets fitted which the K0 models had.So this is what I've tried so far.
From a scrap KO pipe I drilled out all the spot welds front & rear and then rewelded the bracket to a K1 silvers pipe. I wasn't that impressed,marked chrome and found it slightly off correct position.I've seen quite a few of these brackets with the top mtg hole drilled larger so it will fit.Maybe Silencer indentations on rear of pipe are slightly off.So second try removed another bracket from a scrap KO by cutting the whole bracket from the pipe and then grinding all excess metal off from the rear.This then leaves no drilled out spot weld holes to reweld.Then fitted bracket to frame and then silencer in correct position & just spot welded in at rear of bracket.This works and looks OK but still looking for better way.
Now the other day at our local nut and bolt place they had a demo type bolt fitted into a brick with just some sort of resin.Machinary which just vibrates can be bolted down to the floor using these type of fixings.So after a lot of rambling my question is has anybody found anything to bond chrome to chrome & would it just peel the chrome?Theres no real weight at this point but quite a bit of vibration. Regards Chris.
