1 - 2 of 2 Posts
I had to replace the kickstart shaft in my CJ360. Installed fine following the service manual. It actuates the transmission fine. However, when I move the transmission shaft it clicks the kickstart gear inside the case. Through the little peep hole under the kick start I can see that when I move the transmission shaft it also moves the gear. Is that normal operation? I have never worked on this engine before so I don't know how its supposed to sound or not. Thanks
1 - 2 of 2 Posts
